Fluent Case-File saved in parallel/serial
Old   September 12, 2012, 08:25
Default Fluent Case-File saved in parallel/serial
Lilly is on a distinguished road
Dear all,
I got a question concerning case-files in batch jobs.
If I want to run a simulation as a batch job parallel at several cores, does it make any difference for may simulation results whether my case-file was saved in parallel or serial mode during the simulation set up before?
Thanks a million for any help!
Lilly
Lilly is offline   Reply With Quote
Old   September 12, 2012, 08:43
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I'm not expert for batch jobs, but I usually save my cas file as serial and then open and calculate in parallel mode; so I think you will not have any problem..
ghost82 is offline   Reply With Quote
Old   September 12, 2012, 09:34
Marion
Marion is on a distinguished road
Hi Lilly,
I've never had problems either: serial, parallel, different number of cores, batch mode... everything works for me.
Marion.
Marion is offline   Reply With Quote
Old   September 12, 2012, 11:24
Dear Marion, dear Daniele,
that sounds good!
Thank you for your help!
Lilly
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
