Problem in post processing
Like Tree1Likes
  • 1 Post By ashgun
Old   February 9, 2012, 00:32
Question Problem in post processing
Diana
Diana.N is on a distinguished road
Hiall, I'm new to this forum and joined since I have a CFD problem
I need to post process results of Fluent for Nu number and friction factor for concentric pipe under constant heat flux insertedwith twisted tape.
I will much appreciate your advice & comments .
Regards
Diana.N is offline   Reply With Quote
Old   February 10, 2012, 01:31
delaneyluke is on a distinguished road
You will have to create custom-field functions for these parameters as they are not directly available as default variables.
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   February 10, 2012, 04:05
Question Problem in Post processing
Diana
Hello Luke,
Thank for your Advice, but my problem is how to select surface to
post process the result and how to calculate the Nu number for the
pipe especially with inserts.
I kindly ask you to Guide me to calculate Nu number.
Regards
Diana
Old   February 10, 2012, 04:14
http://www.wlv.com/products/databook...ata/db3ch5.pdf
Check out this document, Sub chapter 5.4 talks about pipes with twistred pipe inserts. It gives you the correlation for Nusself number.
With regards to Fluent, if the surface of your interest is already there, you need to select it and plot your variable, or else create an iso-surface and then plot your variable.
Old   February 10, 2012, 09:51
Diana
Hello Luke,
This document I have already, but my problem regards to Fluent, how
can I select the average value of Nu number can I gate on value on the surface of cylinder or different value and then take the average value.
If I do it on what part of report should I take it can guide you me please.
With Regards
Diana
Old   September 24, 2012, 14:21
Post regarding Nu and f
abhi
ashgun is on a distinguished road
u will have to calculate local Nusselt number at different points along d length
to calculate Nu u will need difference between surface temperature and avg.temperature at given cross section. the cross section u can get from iso-surfaces, go to mesh option then along d direction of length create cross sections. There is an option called rake/line. rake (discrete point) u can choose. It depends on u how many sections u want then create surface using rake point at x or y equal to ur radius of pipe u will get surface temperature.( r should be same no i.r. +r to +r and -r to +r).
and avg. cross section temperature u can get it from mass weighted value of temperature over given section.
then Nu= q/ (Tsurface -Tavg.) q= constant heat flux which is known
for f u can find overall f get delta P over test section and average velocity and use dercy weisbatch equation or f= 8 tau/ rho* v^2
i am also working same topic but mine is partially extended twisted tape i hope its useful
ashgun is offline   Reply With Quote
Old   September 25, 2012, 11:43
shoeb khan
shk12345 is on a distinguished road
I need to post processi.e results of Fluent for Nu number and friction factor for concentric pipe under constant heat flux insertedwith twisted tape.
Regards
Nu number is already in built in fluent in temperature pannel so you can plot it directly.
Just make a plane anywhere you want and plot the Nu there.
For friction factor f=16/Re, define a custom function and the plot it in the same above fashion.
Hope that will solve your problem.
Need any help . comment.
shk
shk12345 is offline   Reply With Quote
Old   September 25, 2012, 13:03
abhi
i think 16/Re is theoretical expected value actual value u have to find out by computing pressure drop and velocity
Kamu likes this.
Post processing problem Dawood FLUENT 0 February 8, 2012 22:48
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
post processing dam break problem chris wetton CFX 7 February 22, 2008 06:33
Post processing display problem Jennifer Haque CFX 2 January 18, 2002 11:01
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
