create helical ribbon
Old   February 16, 2006, 05:01
Default create helical ribbon
hamina
please help me to create th geometrie of helical ribbon in gambit thanks
Old   February 16, 2006, 05:02
Default Re: create helical ribbon *NM*
hamina
Old   February 16, 2006, 07:24
Default Re: create helical ribbon by gambit
hamina
please help me tu create hilical ribbon by gambit
Old   February 16, 2006, 19:52
Wael
Hi Hamina, you should try the sweep process , so you can sweep a circular surface to make a helical geometry. Please come back if there is any question. Hope that help you. Wael
Old   February 20, 2006, 05:55
hamina
thank you if you give one exemple step by step in the gambit with the journal of gambit
Old   February 20, 2006, 05:58
hamina
help with the example step by step in gambit or with th jouranal of gambit
Old   February 20, 2006, 08:08
Wael
Sorry for my late response. 1-make a circular Omesh (if the cross section is a circle) 2-make a vertex in the center of the circle 3. make a line using the rotate vertex option using this point, you can put the angle (360 for one turn ---720 for two turns etc.) and put the pitch too. 4. make the volume of the helical geometry by the sweep face command and select the circular face and the line mad in step 3. 5.now you can mesh the volume or in step 1 mesh the circular face as you like, also, mesh the line made in step 3. Using sweep face with mesh that will mesh the volume too. Hope that help you. My best regards. Wael
Old   February 20, 2006, 08:22
hamina
thank you for your kindness is what you puver to give me an example on gambit on the journal of the gambit
Old   February 21, 2006, 08:27
hamina
I have to test but its does not go if you vouler gives me a numerical example if it like to you
Old   October 12, 2012, 06:03
Default gambit helical ribbon creation
kannoju nandini
kannojunandini is on a distinguished road
can anyone plz specify the series of steps to creat helical ribbon in gambit......
kannojunandini is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 09:03
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
