Heat transfer simulation of Gel(high viscous fluid) on a solid plate
Old   August 22, 2012, 06:12
Default Heat transfer simulation of Gel(high viscous fluid) on a solid plate
fshak92 is on a distinguished road
Hi everybody,
Im going to have the thermal simulation of a high viscous fluid(acting like gel) which lie on a solid plate.
Im not sure whether i should define my fluid layer as fluid with high viscous?
Because this layer has the thickness of (e.g 1 cm) and if it defined as a fluid,how can it be maintaned in a fixed shape on a solid plate?(you can see the picture below)
Also this layer would be warmed and in future i like to consider the density changes of that.
Thanks in advance.
fshak92 is offline   Reply With Quote
Old   October 26, 2012, 11:32
Hii,
Nobody has any idea?
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
modeling heat transfer betwwen fluid and solid Al Mazdeh CFX 0 March 13, 2008 10:35
Solid Heat Transfer Simulation diego flore FLUENT 0 February 29, 2008 19:06
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
