please give advise about what I should use.
Like Tree2Likes
  • 1 Post By eng_s_sadeghi
  • 1 Post By RodriguezFatz
Old   October 19, 2012, 11:04
Talking please give advise about what I should use.
ppcandy is on a distinguished road
dear all,
I am new to this forum. I am currently working on oil production analysis.
I need to look into the Temperature distribution and do the analysis for the oil well from surface of ground all the way to down to the bottom of the well.
usually we have big diameter drilling, encaved by a large steel tube (casing). many holes are opened on this tube.
then another tube (production)with smaller diameter goes inside the casing tube and also have many holes opened at the bottom of the well.
fluid is injected into the smaller one, invade in the annular space between two tubes. sometimes fluid is sucked from outside of the bigger tube and invade into smaller also through the annular.
temperatures, pressure, joint effect, valve effect, all thermo process need to be considered in the process.
the result will be a time dependent Temperature profile inside tubes and annular.
I have heard the powerful flenuent. please give some suggest about this. is there anything that is easier to master and functioned enough to simulate this process?
many thanks
ppcandy
ppcandy is offline   Reply With Quote
Old   October 20, 2012, 13:05
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
It seems to be so easy. Please share a schematic to could help you.
ppcandy likes this.
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   October 22, 2012, 18:42
http://www.accessscience.com/overflo...&rootID=795289
Old   October 23, 2012, 04:03
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
If you already have someone who is up to do these simulations, I would ask him/her about the software. If you don't have someone what is your plan? Do it yourself? Then, I think Fluent is the most common and user-frendly software.
ppcandy likes this.
RodriguezFatz is offline   Reply With Quote
Old   October 26, 2012, 09:09
thanks, I don't have anyone using Fluent for this job around me. someone I know been used it for pressure analysis in pipe without thermo involved.
so I guess my next question is that 'can FLUENT model the porous prock outside the tubes?' because it plays important role in heat conduction.
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 02:37
can any body give me an answer about the notice wwwuxing Main CFD Forum 2 December 25, 2010 22:55
How to give volume fraction in multiphase models chhanwal FLUENT 0 August 13, 2009 00:07
How to give mass flow inlet boundary condition kiran Siemens 2 July 5, 2007 22:43
Help! how to give initial VOF Ray Main CFD Forum 3 November 11, 1999 10:13
