Modelling strecthing/shrinking plate in FLUENT
Old   October 24, 2012, 06:34
Post Modelling strecthing/shrinking plate in FLUENT
Deepak .S.Jain
deepak_jain is on a distinguished road
I need to solve the following problem numerically and I thought FLUENT will be a good option .
Problem statement: Flow of viscous incompressible, fluid over a generalized strecthing/shrinking wall.
For the start I prepared a rectangular domain as my flow domain and now while specifying the boundary conditions I was little confused.
The research paper I am referring gives the following BC'ns
for the bottom wall it gives
u(x) = ax+b
v = constant (can be +ve or -ve)
at the far field the fluid is quiescent ... so i suppose for the upper boundary i will have to give u=0 and v=0
I am not able to figure out what to give at the inlet and the outlet also do i need to use UDF for the bottom wall velocity condition and is it a moving mesh problem.
I would also like to know whether openFoam would be easier in this regards??
I was trying to attach the reference paper but seems its too large size...please guide me in this regards.
deepak_jain is offline   Reply With Quote
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Engine modelling using fluent - advice nat2479 FLUENT 0 February 1, 2011 14:18
Modelling two fluids in Fluent skaboy607 FLUENT 7 January 27, 2011 05:55
Modelling an actuator disk in FLUENT teymourj Main CFD Forum 0 April 28, 2009 21:42
Need Help on Fluent Modelling Laminar on BluffBody ary Main CFD Forum 1 May 19, 2005 05:59
