Particle Injection
Old   November 8, 2012, 05:25
Default Particle Injection
Theodoros Papadopoulos
papteo is on a distinguished road
Hi ,
I am trying to simulate a problem where the particles are injected on a rotary disk. I inject the particles using the option surface injection and their velocity 0.1 normal to the boundary. the rotary disk is set to spin with 1000 rpm. the particles are leaving the disk with a velocity magnitude 0.1 m/s and not with 8 m/s, as I calculated before the experiment. I can not use the coordinates for the velocity definition, as a cylindrical definition would have been the right one.
Do you have any suggestions, how I can solve this problem
thank you very much in advance!
papteo is offline   Reply With Quote
User defined particle injection areas yvonne ANSYS 1 March 8, 2023 17:52
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Particle injection boundary condition fjalil CFX 8 September 23, 2009 09:40
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Particle velocity - Injection With Line Weighting Danuta CFX 0 October 10, 2007 06:21
