Problem with pressure jump in 3d problem
Like Tree1Likes
  • 1 Post By paisano
Old   May 30, 2012, 18:55
Default Problem with pressure jump in 3d problem
tula
paisano is on a distinguished road
I have a divergence problem when i use porous jump condition in a 3d problem. I want to model wind passing over a windbreak.
The windbreak was modeled as a solid with 1 mm thickness and it was inserted in a huge control volume. The meshing has like 3 million elements and it was very difficult to mesh.
The control volume is attached
Can anybody help me?
paisano is offline   Reply With Quote
Old   May 30, 2012, 22:50
Guava Wang is on a distinguished road
hi paisano,
the porous model with 1mm thickness can be simplified as a surface, and set the surface as porous jump boundary condition. in this way, mesh will be easy. the main issue is that the surface sliced the solid for interior zone. hope this will help.
regards
Guava
Guava Wang is offline   Reply With Quote
Old   May 30, 2012, 23:10
tula
Thanks for the answer, but the porous jump model can only be applied to interior type zones, not to faces.
I donīt know too much of Fluent, but can I do Surfaces with interior Zones? I think not, but i`m not sure.
Old   May 31, 2012, 04:25
you can do as follows. first divide the model into several parts, and then form a new part in ANSYS DM. the face amid two parts is an interior zone when you import model into FLUENT. that face is taken as the porous jump BC . you can try.
Old   May 31, 2012, 14:33
tula
i wil try it, thanks a lot!!
Old   June 3, 2012, 21:32
tula
When it runs with the porous jump-condition, Fluent Crashes. And when i open the Setup again it appears:
Change zone type [3] (Failed)
Change zone type [4] (Failed)
Change zone type [5] (Failed).
Without the porous jump-condition the software doesn`t crash (with Interfaces and interface interior zone created).
I'm looking for the solution..
Old   June 6, 2012, 07:29
delaneyluke is on a distinguished road
A porous jump is applied to 2D faces and appears under the Boundary Conditions tab
Here you only need to input 3 variables, inertial resistance coeff (pressure jump coeff C2), viscous resistance coeff (Face permeability) and medium thickness
A porous media is applied to a cellzone and allows you to input the same coefficients but in all 3 directions.
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   June 6, 2012, 10:14
tula
Regards
Luke
In 3d problems you can also apply porous jump to interior zones (not to faces). I use porous jump because in the user guide says that has better convergence.
Regards.
Old   June 11, 2012, 13:37
tula
Problem almost solved! the problem that i had is that I couldn't run the model in parallel cores. When I run the problem with serial core nothing bad happens (but it takes too much!). I noted that, when I opened FLUENT and i had the following message:
Warning: Partition method "Metis" is not allowed for
autopartitioning for cases with nonconformal
interfaces before the interfaces are defined
and intersected, use "Principal Axes" instead.
You may use the "Metis" partition method
after the case is read in and the interfaces
are intersected.,
When i change the partition method (Principal Axes), FLUENT crashes...
Anybody know how to solve this?
Joao.carlos likes this.
Old   November 28, 2012, 03:20
Default Porous jump
Kamu is on a distinguished road
Regards
Luke
Dear Luke
How does FLUENT treat an inclined surface when specified as a porous jump? I am analyzing heat transfer enhancement with inclined perforated plates?
Thanks in advance
Kamu is offline   Reply With Quote
Pressure inlet problem Laci FLUENT 2 October 5, 2010 04:51
Pressure calculation problem maolongliu OpenFOAM 1 August 15, 2010 08:05
problem with pressure force report jvd FLUENT 0 August 3, 2010 02:19
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
