UDF - define_init & restart problem
Old   December 3, 2012, 16:27
Question UDF - define_init & restart problem
Ján
argeus is on a distinguished road
Dear friends,
There is one thing I cant figure out. I interpreted my UDF which was made as follows:
Define_init function. Is to examine the geometry parameters, to simplify it, it returns the total volume (c_tot variable) of the cells.
Define_source (whatever define macro), uses this value, such as x/c_tot. Everything works fine, until I end the calculation, write a .dat file and restart the calculation without initialization. Seems to be (and Im pretty sure), that Fluent does not store the c_tot value, in general any value, obtained from define_init once the calculation is over and then restarted. I really dont want to use a define_adjust (it will uselessly slow down my calculation), or define_on_demand (want to keep it to be performed automatically). Is there any way to store that value for the next usage?
Thank you in advance.
j.
argeus is offline   Reply With Quote
Old   December 4, 2012, 11:19
Ján
Hi again,
so it seems to be that I moved on a bit.
I found out that use of C_UDMI could be suitable for this kind of problem, anyway there is still an issue I cant pass through.
To explain it more closely:
DEFINE_INIT (init, domain)
  real ...
  thread_loop_c(t, domain);
      begin_c_loop(c, tc)
        if (sth)
        C_UDMI(c, tc, 0)+=C_VOLUME(c, tc);
      end_c_loop(c, tc)
and then
DEFINE_SOURCE(energy, c, thread, dS, eqn)
   real ...
   var1=var2/C_UDMI(c, tc, 0)
   source=var3;
   dS[eqn]=var4;
   return source;
Please have a look on that. Problem is, that C_UDMI is returning zero value (as an output from ini function), and I dont have a clue why.
Maybe I just dont understand how C_UDMI is working.
The second question is - Will be the C_UDMI value stored after I re-interpret my UDF, or restart the calculation from a .dat file? (Will be this value written into a .dat file?).
For now, Im using on demand macro, but it is not so pretty as I would like to..
Regards
.dat, define_init, restart, udf
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
UDF Problem ozgur Fluent UDF and Scheme Programming 18 January 17, 2016 14:40
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
fluent udf problem for 3d case srsahu Fluent UDF and Scheme Programming 0 July 28, 2009 07:25
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
