the result of the velocity and pressure drop is a little strange.
Old   December 18, 2012, 19:48
Default the result of the velocity and pressure drop is a little strange.
Rong Yue
yuhehuan is on a distinguished road
Hi, everyone. I simulated the airlow in a box(0.25m*0.02m*0.25m) using fluent, the velocity at inlet(the bottom surface of the box) is 0.05m/s, and got the pressre drop at outlet (top surface) is 6pa/0.25m, which is close to the value i calculated by using Ergun equation. But the problem is the facet average velocity at the inlet and outlet are aslo 0.05m/s. It seems the velocity doesn't reduce from the bottom to the top. Is it resonable? And if i used a circle (r=0.005m) as the inlet, the pressure drop is very low, like 0.1pa/0.25m. So i think the pressure drop is too small. Does anybody explain it for me? I will appreciate your reply! Many thanks!
yuhehuan is offline   Reply With Quote
Low pressure result in low velocity region for RNG-ke? Gabbee90 OpenFOAM Running, Solving & CFD 0 July 14, 2011 20:48
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
