Floating Point Exception in reaction channel
Old   December 19, 2012, 04:56
Default Floating Point Exception in reaction channel
idil tezcan
idil is on a distinguished road
Hello, I'am trying to simulate a highly exothermic reaction mechanism in a microchannel reactor. Solution Initialization gives an error: foating point exception. And I can't proceed to iterations. Is it about the solver parameters or my initial conditions? Anyone can help?
idil is offline   Reply With Quote
Old   December 19, 2012, 06:55
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hey,
In 100% of the cases this happened to me is was due to a mesh error (negative volume / faces error...). Did you check your mesh?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   December 19, 2012, 07:00
idil tezcan
yes I checked the mesh, no negative value for volume or face area. mesh seems normal. Also I checked my rxn and diffusivity udf's they're normal too. What could be the cause of this problem?
Old   December 19, 2012, 07:03
Philipp
Why don't you start a new project and load the mesh. Maybe set some simple BCs.
Now try to initialize. If this works then switch on all "extras", but one by one. Try to initialize each time.
Old   December 19, 2012, 07:33
idil tezcan
Actually I assigned the BC's in gambit (velocity in-, pressure out, interface etc.) then read the mesh in fluent and I put initial values to speicific boundries ( superficial velocity etc) in fluent. Is it OK to assign the BC's in Fluent? because it is hard to identify default names fluent gives to different boundaries. by the way I have 2D geometry and 4 different layers in my system (up-to down: coolant-wall-catalyst-channel)
Old   December 19, 2012, 10:09
Philipp
I am sorry, I allways set the BCs in fluent...
floating point exception, microchannels
Floating point exception with pimpleDyMFoam ebah6 OpenFOAM Running, Solving & CFD 9 November 1, 2017 05:58
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 10:21
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 16:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 03:24
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
