time dependent BC with fully developed velocity profile |
June 22, 2010, 14:13 |
Susheil Uthamaraj
Rep Power: 15 |
I am trying to simulate a pulsatile flow through a blood vessel. For doing this I created a profile file (*.prof) to generate a pulse required and applied this as a velocity-BC at the inlet. But this BC is a constant spatially.
For my purpose we would need a velocity pulse which is also fully developed. In other words, The how to apply a BC which varies both with respect to time and with respect to space. Thanks. |
June 22, 2010, 17:36 |
Jouke de Baar
Rep Power: 16 |
What a nice problem.
You can do this quite easily using a user defined function (UDF). This means you will have to write a very short .c file and then compile it from FLUENT. After that you can use it as a boundary condition. It is quite possible to multiply a fully developed parabolic profile with a time dependent sine. Or whatever you want really. Have a look at: http://www.hipecc.wichita.edu/pdfs/fludf.pdf |
June 22, 2010, 17:44 |
Jouke de Baar
Rep Power: 16 |
And then check the DEFINE_PROFILE for a velocity profile. If I remember correctly the function CURRENT_TIME should give the physical time you will need.
Good luck! |
June 23, 2010, 10:43 |
Susheil Uthamaraj
Rep Power: 15 |
Thanks,
The problem I am facing is that inlet in my model is not circular it is an irregular shape since this is blood vessel problem. |
June 24, 2010, 08:44 |
Jouke de Baar
Rep Power: 16 |
I'm afraid I can't help you there. Fluent can use an experimentally determined inflow profile, but I don't think this can be time dependent. There must be some smart way to do this, hopefully somebody else knows how?
Good luck! |
June 24, 2010, 09:27 |
Thanks
Susheil Uthamaraj
Rep Power: 15 |
Thanks Jack. I will try to figure it out. Will post If i find out.
transient, velocity profile |
Display Modes | |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
Modification in a Time Dependent Velocity | Guillermo Solano | Phoenics | 4 | April 8, 2002 03:34 |
