September 20, 2022, 15:01 |
Validity of the Drag Force acting on a Wing
HS
Rep Power: 3 |
Hi Everyone,
I ran a CFD analysis on NACA 0006 wing at 0 angle of attack. The root length,tip length and span of the wing is 10cm,8cm,10cm respectively.The freestream velocity is 300 m/s and pressure is 1 atm (sea level conditions). When the analysis is completed the drag acting on the wing is 5N which corresponds to a drag coefficient of 0,005. I am new to CFD but this number seemed so small. Can this be correct? For further information: in the mesh part, I have a minimum orthogonal quality of 0.0138,maximum skewness of 0.95 and maximum aspect ratio of 792 (I checked orthogonal quality and aspect ratio from Fluent). The first layer thickness is 2.5e-6m. I have 15 number of layers with a growth rate of 1.2. In the setup part I converted the mesh to polyhedral mesh. I used density-based solver,ideal gas model and SST k-w turbulence model for air. I also share the mesh and mach number contour I get. Thank you in advance. |
September 21, 2022, 03:01 |
Lucky
Rep Power: 65 |
I'm trying a bunch of different combinations like 5*2/300^2/.01^2 ~ 1, how do you get 0.0005?
September 21, 2022, 05:36 |
HS
Rep Power: 3 |
I obtained the surface area from 3D CAD software. So my calculation is : (5*2)/(1.2*0.01838257*300^2) ~ 0.005
September 21, 2022, 11:54 |
Lucky
Rep Power: 65 |
Your projected frontal area should be (10 cm * 6%*10 cm) and your planform area (10 cm x 10 cm). Your reference area is going to be one of those or close to one of those and you need to use the drag coefficient corresponding to either definition. If you use the planform area then you get really small values for Cd. Drag coefficient normally uses the frontal area but sometimes the planform area is used in order to keep the same area as the lift coefficient.
September 21, 2022, 12:04 |
HS
Rep Power: 3 |
Oh I get it. But still isnt this force very small for such an high velocity?
airfoil, fluent |
Extracting Drag Force | mishblair | FLUENT | 0 | July 24, 2019 09:56 |
FLUENT: how to record drag force at every time step? | qiulan | FLUENT | 4 | March 20, 2017 21:22 |
Determination of the induced Drag for a rectangular wing | matmax-168 | CFX | 3 | April 12, 2015 07:46 |
Regarding modified drag force formulation for application in dense flows | ansubru | OpenFOAM Programming & Development | 15 | September 14, 2014 09:04 |
Isolating wing induced drag component | siw | CFX | 2 | June 22, 2010 10:21 |
