May 9, 2006, 09:25 |
C_VOLUME
Hello
I'm trying to get the volume of each cell in my geometry. I am in 2D axisymetrique. I kno that C_VOLUME(cell, thread) give us the volume of each cell, but when I sum all my cell volume I don't have the right volume of my geometry. My geometry is a simple tube: r=0.05m and L=0.15m So the volume will be V=pi*r*r*L=1.17*10^-3 But when I use C_VOLUME I find V=1,87*10^-4!!! I don't understand why??? Could anyone help me please? Thanks |
May 9, 2006, 09:32 |
Re: C_VOLUME
I try to use C_VOLUME_2D but it give me the volume as if I wasn't in 2D axisymetric but only in 2D So it give me V=L*r*1=0.0075
May 9, 2006, 09:38 |
Re: C_VOLUME
One possibility is that you donīt have set the right scale-factor. You can check it there :
grid / scale |
May 9, 2006, 09:50 |
Re: C_VOLUME
Thank you. But I verify and I set the good scale. C_VOLUME work well when I'm in 2D, so my function seems to be correct. But in axisymetric it does'nt work.
May 15, 2006, 11:43 |
Re: C_VOLUME
C_VOLUME returns cell_volume/(2*PI) for axisymmetric.
RoM |
May 15, 2006, 11:47 |
Re: C_VOLUME
thank you... It's work
January 21, 2013, 01:45 |
Rep Power: 16 |
Dear Gernot,
where can i check for grid/scale please?
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
January 21, 2013, 02:10 |
problem in cell volume value for source term
Rep Power: 16 |
Dear all,
i may have a problem in using C_VOLUME to calculate the source in my UDF application. i've the following UDF code that attempts to apply a temperature-dependent source term to a solid cell. #include "udf.h" #include "mem.h" DEFINE_SOURCE(cell_x_source,cell,thread,dS,eqn) { real source; int Ro=12e-3; /*12mOhm at 20C*/ int To=20; /*temperature 20C*/ int Iphase=20; /*Arms*/ source=Iphase*Iphase*Ro*((C_T(cell,thread)-273)/To)/C_VOLUME(cell,thread); Message("C_T output: %g\n",C_T(cell,thread)); Message("source output: %g\n",source); Message("C_VOLUME output: %g\n",C_VOLUME(cell,thread)); return source; } While running 100 iterations, i observe in the Message output that the C_VOLUME of the solid cell is changing rather than keeping at a constant value as expected. why is this happening please? The final outcome of the run was: Error: Divergence detected in AMG solver: temperature Error Object: #f Then, i go into the solid cell's 'Parameter' menu (as shown attached), and verified that the volume it calculates in the output parameter is correct: 2.57e-5 [m3]. How can i use this output parameter in UDF please? Hope to receive any comments/ideas you may have. __________________ Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13
Display Modes | |
