Problems when using level set
Old   March 25, 2012, 11:27
Question Problems when using level set
Zh
adsl17754 is on a distinguished road
I tried to simulate a swirl hollow cone spray using Fluent. It was OK to use VOF method, but problem came when I tried to coupled level set with VOF. "No intersection facet found in partially filled cell" kept showing on the screen, and the program seemed not responding then... Has anyone ever met the same problem? I am a novice, Thanks for attention~
adsl17754 is offline   Reply With Quote
Old   March 28, 2012, 04:43
Question Maybe the meshing quality was poor
Zh
Hi,everyone~
I still don't know how to solve the problem, but now I am sure that the boundary conditions for VOF+Levelset are OK. So I guess it was a Meshing problem, Report Quality in Fluent showed that minimum orthogonal quality was 0.0039, was it too low for a 3D mesh? Thanks~
Old   January 10, 2013, 19:23
Reza
rk_k67 is on a distinguished road
I sometimes have a problem with running fluent in parallel for some meshes, which could be due to the trading information between domains and the fact that the phi function in level set can not be split and it would be hard to make the Phi distance function to overlap exactly on the same position where the domain is partitioned. that is where I think error comes from !!!!! ? ! ? ! Although all my meshes are fully squared, I still get the problem. Also, I just tried it differently and I got your error. Did you manage to fix your problem and get CLSVOF running !
Cheers
rk_k67 is offline   Reply With Quote
Old   January 10, 2013, 21:39
Smile one probable solution
Zh
Originally Posted by rk_k67 View Post
Cheers
Hi rk_k67,
That's a reasonable explanation~ Parallel in FLUENT sometimes causes that problem, try to use "serial" to calculate for several iterations, then switch to "parallel", that solved my problem. Hope it works for you~
Cheers
Old   January 13, 2013, 17:17
Reza
Originally Posted by adsl17754 View Post
Hi rk_k67,
Cheers
Thanks. yeah I do the same. I run it for a bit on serial and then I switch it to parallel and it runs for a while, but it still crashes after a little while. Have you had the same problem ?
level set method
tracking the front of detonation by level set Amir Main CFD Forum 3 September 2, 2008 06:02
tracking the front of 2-D detonation by level set Amir Main CFD Forum 0 September 1, 2008 05:22
Reinitialization for level set Amir Main CFD Forum 6 August 31, 2008 02:37
mass loss in Level Set dusky.he Main CFD Forum 8 February 9, 2007 08:40
Level Set in Cavitation Modeling Niklas Wikstrom Main CFD Forum 1 September 9, 1999 13:08
