January 14, 2013, 07:21 |
velocity profile
Rohit kumar Mittal
Dear friends,
i am trying to plot the velocity profile for a flowing fluid at cross section of open channel using fluent. I have done modelling as well as meshing. Beside these in fluent, i have switched on gravity, in models, i have chosen volume of fluid model>open channel flow, checked energy equation and used k-epsilon (2 eqn.). I have given water as primary and air as secondary phases. Besides these all are set as default. Still i am not getting the correct velocity profile. please help me. I got stuck since a long time. |
January 18, 2013, 16:16 |
Rohit kumar Mittal
Dear friends,
is there no one who is able to help me? |
January 19, 2013, 04:31 |
SSL
It is an easy problem.
Which boundary conditions have you use? There is no need to enable energy equation. |
January 19, 2013, 05:29 |
Rohit kumar Mittal
Sir,
boundary conditions are as follows: (1)At velocity inlet- v=0 at inlet initial gauge pressure= 0 turbulence specification method- Intensity and hydraulic diameter temperature= 300K (2)At pressure outlet- back-flow direction specification method- Normal to boundary turbulence specification method- Intensity and hydraulic diameter temperature= 300K checked the open channel in multiphase tab where- pressure specification method- from neighbouring cell bottom level i selected which is at outlet side. (3)Stationary walls- wall motion- stationary wall shear condition- no shear wall roughness- roughness constant= 0.5 roughness height = 0 wall adhesion- contact angle(air-water)= 90 degree All remaining conditions are default. |
January 19, 2013, 05:55 |
SSL
in open channels you should use outflow instead of pressure outlet.
January 20, 2013, 08:02 |
Rohit kumar Mittal
As per your saying, i used outflow instead of pressure outlet.
What is flow rate weighting? Although i took its value equal to one. But still i am not getting the correct velocity profile. Sir, if you have already done it before, kindly mail me the way in which i should proceed at rkmittal1108@gmail.com I will be very thankful to you. |
January 20, 2013, 09:08 |
SSL
Set it 1 if you have just one outlet. Else you should define fraction of flow that gets out of the domain from each outlet.
[UDF] Relative coordinates in logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 25 | July 13, 2017 03:44 |
Logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 0 | April 23, 2009 19:09 |
[boundary condition] logarithmic velocity profile | cfdworker | FLUENT | 2 | April 17, 2009 23:36 |
Prescribed inflow velocity profile - how to? | Alan | Main CFD Forum | 10 | October 28, 2005 12:14 |
