Negative-cell volume error for water entry problem |
January 19, 2013, 10:23 |
Stefanos Katifeoglou
Rep Power: 14 |
Dear community,
I am trying to simulate a steady velocity motion for a 2D cylinder water-entry problem by using the VOF method in Fluent 13.0. I have already checked the functionality of VOF method within Fluenr for free-surface modeling, by solving a steady-state case. Thus, now i am using a DEFINE_CG_MOTION UDF with a steady vertical velocity for the solid boundary motion. Due to the quad mesh i use the Smoothing and Layering options for the deforming mesh. Next, i assign the rigid body motion at the moving wall and at a moving fluid zone outside the wall which includes the boundary layer, while the deforming zone is set at the surrounding fluid. However i get the "Negative-cell volume" detection error. I have also noticed that at the Dynamic Mesh Zones panel there are more than one zones referred to only one, e.g., for the deforming fluid there is a zone "fluid" and a zone "interior-fluid" as well. I have tried to solve by assigning the deforming zone option at only one of the two labels and at both labels, as well and, at all cases, the negative-cell volume problem remains. I would be very thankful if someone gave me an idea for facing this problem. Regards |
Display Modes | |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Cell has a zero or negative volume | Nick | Siemens | 10 | February 12, 2020 21:06 |
Negative cell volume problem | schuny | FLUENT | 8 | April 10, 2012 06:16 |
negative cell volume during dynamic meshing | Tamjid | FLUENT | 1 | September 5, 2011 03:33 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
