Fluent Error Message
Old   January 22, 2013, 13:21
Default Fluent Error Message
OMJT is on a distinguished road
Hi everyone,
I am trying to run a simulation with a Porous Jump in it and get this error which I do not understand:
Error: set_polynomial:wta[car] float
Error Object: inf
The simulation is just a transient simulation of a porous jump (face permeability set to 0) run with k-w SST turbulence model. The mesh is imported from ICEM CFD and has had no issue being run before.
Thanks for any help!
Matt
OMJT is offline   Reply With Quote
Old   July 12, 2013, 16:57
Anonymous
CCarl is on a distinguished road
Having same problem. How did you fix this?
CCarl is offline   Reply With Quote
Old   July 12, 2013, 18:55
I solved it by loading a new mesh I built that was exactly the same...
However, the error could also be caused if your permeability coefficient is set to 0 I think too. Look at the fluent equation for the pressure jump create by the porous jump. I haven't used fluent in a while
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
