Do successfully worked MHD module examples exist?
Like Tree3Likes
  • 1 Post By Peterpanza
  • 1 Post By nasser
Old   December 10, 2012, 01:05
Default Do successfully worked MHD module examples exist?
Yafei Li
Peterpanza is on a distinguished road
I tried to simulate the plasma arc welding process, I found MHD module iperfectly suits my need, but haven't worked out anything yet, all the variables in user defined memory are zeroes.
I would be very very grateful if anyone can share a successfully worked MHD module example
nasser likes this.
Peterpanza is offline   Reply With Quote
Old   January 20, 2013, 10:08
Nasser
nasser is on a distinguished road
hi friends
I have the same problem , do you solve it ?
nasser is offline   Reply With Quote
Old   January 20, 2013, 20:30
Yafei Li
Originally Posted by nasser View Post
hi friends
yeah,i had ,or i should say I hadn't
cause it just can not solve that kind of problem.
Now I am trying to solve it in old way with UDF and UDS,luckily,it is a 2-D module.
Old   January 20, 2013, 20:34
Yafei Li
hi friends
well, I mean i need it to work in this way:
put a current in the middle, and it generates a magnetic field,then put the Lorenzo force in the momentum equations as source term.
Maybe it can do that, but I failed to discover how
Old   January 21, 2013, 10:22
Yanlong Li
Yanlong Li is on a distinguished road
Did you use VOF model together?
Yanlong Li is offline   Reply With Quote
Old   January 22, 2013, 01:47
Yafei Li
Sorry pal,i dont need VOF to solve my problem, it is only a single phase problem
Old   January 22, 2013, 01:58
Nasser
hi friends
I think I can use MHD in my model but I dont Know about Accuracy of it.
Old   January 22, 2013, 02:13
Yafei Li
hi friends
Do you have induced magnetic field in your model?
Old   January 22, 2013, 04:32
Nasser
yes , I induce magnetic field in my model and it worked .
Old   January 22, 2013, 05:37
Yafei Li
Do you mean you have a existing current,which is intended to induce a magnetic field?
May I know your model in detail?
Old   January 26, 2013, 11:29
violin is on a distinguished road
[QUOTE=Peterpanza;4a current to induce a magnetic field !
violin is offline   Reply With Quote
Old   January 26, 2013, 11:38
Nasser
No , I only have magnetic field . fluent cant model a current to induce a magnetic field .
yashganatra likes this.
Old   January 27, 2013, 20:25
Yafei Li
yeah.....i had spend weeks figured that out. Thx anyway
mhd
MHD Module Ashish FLUENT 2 November 18, 2017 03:40
B vector in mhd module. adamo Fluent UDF and Scheme Programming 7 May 22, 2012 06:26
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
