Sliding mesh and Momentum Theory
Old   March 9, 2004, 15:13
Default Sliding mesh and Momentum Theory
Lam
I have model a ship propeller and rotate it using sliding mesh method. The CFD prediction seems lower than the experimental results. As your information, the CFD and experimental predictions on velocity (dimensionless) are 0.82 and 1.1 respectively.
So, I try to understand how does the sliding mesh method working. There is a question,
When the propeller is rotating at 1000rpm, does the system assume it as an actuator disk which the flow passing over uniformly without any energy losses like the assumption in momentum theory?
For anybody who have experienced this problem may be can give me a hand. Is that any relation between the sliding mesh and momentum theory? What is the assumption of the sliding mesh method? Or may be I think too much...
Lam
Old   August 4, 2009, 22:17
Khaled
Almohammadi is on a distinguished road
I am facing same problem? Any Idea??
Thank you
Originally Posted by Lam
;110992
Lam
Almohammadi is offline   Reply With Quote
Old   February 21, 2013, 16:08
Ludvig is on a distinguished road
I am trying to do a sliding mesh setup aswell!
Struggling to do the interfaces in icem, how do you do this?
Thanks a lot for your help
Ludvig is offline   Reply With Quote
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Governing equation of sliding mesh f0208secretx FLUENT 2 December 10, 2012 03:41
x-momentum urf and sliding mesh kike FLUENT 1 August 1, 2011 17:07
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
sliding mesh and momentum sources term run error luan Siemens 4 June 29, 2008 18:38
