Stationary mesh interface causing divergence in FSI sim. |
May 6, 2016, 17:21 |
Kegan Leckness
Rep Power: 11 |
Hi all,
EP Chamber malfunction.jpg I'm modeling a complex system that includes pipe flow. The pipe is in sections such that the fluid in the pipe meets another fluid zone via fluid-fluid interfaces. [The fluid domain of the pipe must be in separate sections for dynamic remeshing settings purposes.] What's happening is the outside surface of the fluid is in motion with the structure of the pipe via FSI, but the faces of the fluid-fluid interfaces remain stationary such that part of the domain is moving, and part of it isn't, which results in poor element quality/divergence. The image above shows the deformation of a small section of the pipe's fluid domain. How might I avoid this circumstance? I want the fluid-fluid interfaces (and fluid zones between them) to move with the structure - I do not want stationary interfaces. The motion of the pipe's structure is not known; I want the fluid-fluid interfaces to move freely as I cannot predict what their motion should be. Thank you, Kegan |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 05:57 |
[Other] Mesh refinement and smooth interface shape | Prosper | OpenFOAM Meshing & Mesh Conversion | 2 | May 5, 2015 15:21 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
