Postprocessing using CFD Post -Problem/Help
Old   April 7, 2013, 13:34
Default Postprocessing using CFD Post -Problem/Help
Elina Mathew
elina is on a distinguished road
Hi Friends
I am doing a CFD heat transfer Simulation using Fluent and I need to find the outlet temperature for a given Inlet temperature and velocity and in my case there is a sphere inside a channel of Fluid...so There will be heat transfer from the hot fluid to the sphere..And hence I need a graph showing the outlet temperature based on the time in seconds...so
For Ex
Inlet temp = 370 K
Sphere 7 Initial Fluid Temperature = 300 K
And have to find the out let Temperature say after 5 seconds or something..should I use Transient simulation or Steady state will be enough...?? Am a beginner kindly help me...
elina is offline   Reply With Quote
Old   April 7, 2013, 13:39
Default Steady State or Transient
Elina Mathew
Hi Friends
Can anybody tell me whether the Transient simulation is the same as periodic boundary condition ..??
I have to calculate the outlet temperature after 5 seconds for a flow above a sphere which is in atmospheric temperature(300K)...and the inlet temperature is 370 K..So kindly tell me whether the periodic boundary condition is the same as doing transient simulation or both are different..??
Old   April 7, 2013, 17:47
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hi
What do you mean by saying that periodic boundary condition is the same as transient simulation? I can't make any sense from your points. Transient simulation is kind of simulation which depends on time and flow properties at each point change with time but, periodic boundary condition depends on the geometry of your model. For instance, in a stirred tank, you can consider only a quarter of the tank in your model instead of modeling the whole tank as long as all angular conditions inside the tank is similar, i.e. there's no baffle or feed pipe. Periodic boundary conditions requires its own strategy when you model your geometry, I mean some adjustments in modeler. As far as I know there's a tutorial regard this in fluent I suppose a series of pipes that hot air flows above it. Hope it help.
Regard yours
A CFD free user is offline   Reply With Quote
Old   April 9, 2013, 06:40
Elina Mathew
Ah ok..
For me also I have to consider only a quarter of the geometry and is named as symmetry in all the faces around...But the problem is I have to find the temperature at the outlet of the duct say after some seconds...and its mainly to study how much temperature is absorbed by the metal cube inside the duct
Old   April 9, 2013, 16:06
A-A Azarafza
Hi again
Maybe you need to do your simulation by considering both periodic and transient conditions. If you give me more details of your work, maybe I'll be able to help you.
Regard yours
Old   April 11, 2013, 07:14
Elina Mathew
Hi hope you got my message..kindly reply to my msg when you are free...
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
calculating output parameter in cfd post markus67 CFX 3 August 26, 2015 09:28
Setting the desired Zoom level in ANSYS CFD Post for custom reports shreyasr CFX 1 July 11, 2013 01:57
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
