March 5, 2013, 05:27 |
Pressure Coefficient on shadow walls
Rep Power: 13 |
Hi everybody,
My domain is made of a building, with solid walls and the air surrounding it (inside and outside). Importing the mesh in fluent, the software has created wall and shadow walls for the building. Somobody knows how what should I do to calculate Pressure Coefficients on each wall of the building? I obtain values both on a wall and on its shadow, so I could summ up all the values obtained?Or I should consider just the shadow wall? Thanks |
March 14, 2013, 10:18 |
Rep Power: 17 |
A shadow wall occurs when you have an internal wall with a fluid mesh on either side of the wall.
Generally the results on a wall will be the same as that on the shadow. So when post-processing you can use either of the two, it should be the same. Regards Luke |
Display Modes | |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench | aarvay | ANSYS Meshing & Geometry | 11 | January 12, 2017 13:51 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 16:00 |
XY plotting pressure coefficient on the wall | Yucel Ozmen | FLUENT | 2 | January 16, 2006 22:36 |
Problem in Result of the pressure coefficient | Ken Choi | Main CFD Forum | 2 | March 15, 1999 05:15 |
