WARNING:''cannot create surface from sliding interface zone''
Like Tree9Likes
  • 1 Post By vasava
  • 2 Post By CFDiran
  • 6 Post By kunvd
Old   November 26, 2012, 01:38
Default WARNING:''cannot create surface from sliding interface zone''
Bahar
bahar is on a distinguished road
Hello everybody,
I'm working on a 3D helical H-rotor wind turbine and using moving mesh to simulate fluid.
I received this warning during mesh checking:
''cannot create surface from sliding interface zone'', Is it important enough to notice?
What should I do so?
p.s: domain picture is attached.
Thank you in advance for your attention
Bahar
bahar is offline   Reply With Quote
Old   November 27, 2012, 09:34
Tomek
sondinho is on a distinguished road
Originally Posted by bahar View Post
Hello everybody,
Bahar
I've got the same message while simulating dynamic motion of valve. But the results are ok so I would ignore that in your case.
sondinho is offline   Reply With Quote
Old   November 28, 2012, 00:24
Bahar
Dear sondinho,
Thank you in advance for your attention.
I have serious problem by residuals. Really, in unsteady flow Epsilon residual began to fluctuate until all residuals increase tremendous and finally solution diverge; however, in steady case didn't appear any problem.
Again, I appreciate your attendance.
Old   November 28, 2012, 01:32
Jamal Foroozesh
jamalf64 is on a distinguished road
I think interfaces are very important for moving mesh(sliding mesh) but when you are using MRF and you have conformal mesh they are not important.
if you show me your geometry without mesh, maybe I can halep you but I dont sure.
Be Success.
jamalf64 is offline   Reply With Quote
Old   November 28, 2012, 02:14
Bahar
Dear Jamal,
Thank you in advance!
I've already attached an obvious picture of blades, I have defined required surfaces as interface but I cannot understand why such a problem appear?
Be success.
Old   December 14, 2012, 09:37
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you create interfaces-couple in Fluent? (grid/interfaces)
Once it is done, you can re-check the mesh and then the warning should disappear
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 14, 2012, 14:26
Bahar
Dear mAX,
Thank you for your attention!
Already, I have defined all sliding surfaces as ''Grid Interfaces''! but I recieve this warning in both 2D and 3D flow!
Best Regards,
Bahar
Old   March 21, 2013, 04:45
Smile
Kunal
kunvd is on a distinguished road
Hello bahar, have you got the solution to the problem ?
kunvd is offline   Reply With Quote
Old   March 22, 2013, 07:53
Bahar
Hello kunvd,
This warning did not disappear in my solution while checking results showed that it do not have critical effect on solution.
Old   March 22, 2013, 08:36
Paritosh Vasava
vasava will become famous soon enough
Did you name the walls related to the interface? If you did, you can delete the name and then import the the mesh. Just to check if fluent can deal with the 'un-named' faces itself.
bahar likes this.
vasava is offline   Reply With Quote
Old   March 22, 2013, 08:53
Smile
  #11
CFDiran is on a distinguished road
Hi
Your warning is not very important.
I think that this warning is due to differences in the size of the element in sides of interface.
bahar and f.kh like this.
CFDiran is offline   Reply With Quote
Old   March 22, 2013, 14:00
Kunal
This is my experience...During the interface creation, empty 'wall' s are created. So, while displaying the mesh, if these empty 'wall's are selected, the warning appears.
P.S. Empty in the sense, these boundary conditions are not applied in your mesh.
brucecumt, Abhya, CFDiran and 3 others like this.
Old   March 22, 2013, 15:03
Default reply to kunal
  #13
Gowrav Shenoy
Gowrav is on a distinguished road
yes i got the same..
Gowrav is offline   Reply With Quote
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
