how to find coating thickness using. fluent....
Old   March 24, 2013, 12:30
Question how to find coating thickness using. fluent....
Sumeet Kotak
sumeet kotak is on a distinguished road
hello friends,
I am simulating electron bram - physically vapour deposition system to find out deposited coating thickness...
using transient analysis... ie. after 5 min.
my Questions
1. is there any provision to find thickness directly by fluent.....? if no.. so how could i calculate...?
2. I have one method but not sure whether it's correct or not... an also have some doubt related to this....
the method
step 1 : define custom variable in fluent
mass deposited=density*area*velocity*time step size
i.e.
mass deposited = density*pi/4*(0.016)^ 2 * velocity *0.005
step 2 : manual calculation
volume = mass deposited /density
volume = area* height
than I can found height.....!!!!
please tell me by above method can we find thickness....!!!???? please suggest me modification or. alternative method.....
but I have doubts related to method....
in step 1's equation, density is calculated by fluent after every time step or I have to give constant value manually......
in step 2 equation which density I should use.....?as I used in boundary condition (i.e. 2250) or any other.... in simple way the density used in step 1 and step 2 equation should be same....???
looking for early reply....
thanks in advance
sumeet kotak is offline   Reply With Quote
Old   March 25, 2013, 02:54
Paritosh Vasava
vasava will become famous soon enough
Are you using Volume of Fluid or multiphase approach?
vasava is offline   Reply With Quote
Old   March 25, 2013, 03:22
Sumeet Kotak
I am using species transport model and reaction mechanism is on.... n I have 5 species in my model named
y2o3 -yttrium oxide
yo - yttrium monoxide
o2 -oxygen
o- atomic oxygen
y- yttrium
reaction is
y203 converts in yo + o
yo converts in y + o
y + o2 converts in y2o3 ..... coating deposited on substrate..
Old   March 25, 2013, 03:29
Paritosh Vasava
Can you see the volume fraction of the coating material in Fluent? If not can you export it?
Once you export the volume fraction data you could process it with excel or matlab.
Old   March 25, 2013, 07:32
Sumeet Kotak
from where we can check for volume fraction...?
Old   March 25, 2013, 08:42
Paritosh Vasava
In contours and then phases.
Old   March 25, 2013, 08:49
Sumeet Kotak
there is no any option like volume fraction in my cars I think it's only available in multiphase model n I am using species transport model......
Old   March 25, 2013, 09:11
Paritosh Vasava
My apologies. I completely forgot about that.
Old   March 25, 2013, 09:28
Sumeet Kotak
it's ok... sir... thanks for coming ahead to help me.... appreciate ur efforts....
can u suggest any other model for my project which i can use.....????
Old   January 21, 2015, 02:54
Default Similar problem
Dawood Al-Mosuli is on a distinguished road
Hello Sir,
Did you get an answer to you question. I am dealing with a similar problem which is the Dust particle precipitation on surfaces. i use the discrete phase model and succeed to get the rate of precipitation in micron/sec. I couldn't pick the time or iterations to multiply it by this rate of precipitation and get total film thickness.
Doing this manually is a bad idea because I can't do it for thousands of points. Using excel will not enable me to draw a contour of film thickness variation wit position.
If you got an answer to your questions that will so useful for me and I shall be so grateful to know about it.
Thank you
Dawood Al-Mosuli is offline   Reply With Quote
Please help: - To find torque in Fluent.......... Jayanth FLUENT 1 July 5, 2018 17:23
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
How to find Lift/Drag ratio of a compelx wing in FLUENT kjayatunga FLUENT 2 August 31, 2010 04:02
can FLUENT simulate the liquid film thickness fadhil FLUENT 1 March 11, 2009 06:48
where to find old version Fluent tutorial guid Roger FLUENT 0 March 11, 2002 17:04
