June 28, 2013, 14:28 |
Angular Velocity of the particle
Rep Power: 14 |
I am using DPM model and trying to simulate flow of few particles through fluid. How do I know if my particles are having any angular velocity? And if not how can i impart angular velocity? I have enabled Saffman Lift but it is not generating any lift on my particles. Thanks. Varad. |
June 29, 2013, 05:52 |
Answer
Hi mate,
I am rather sure DPM can not see angular motion of particles. You see, particles should be too small, hence angular velocity would be negligible. About Saffman force, if particle and flow velocities become equal, which will be after a while, Saffman force is zero.
ICEM, CFX and Fluent expert |
June 29, 2013, 09:34 |
Rep Power: 14 |
Thanks for your reply.
Yes that is what is exactly happening. The velocities of particle and fluid becomes equal after a while. So which model should I adopt if I want to simulate particulate flow and see the translational and angular velocity effects and lift on the particles too. |
June 29, 2013, 09:40 |
Answer
To see that you need to model 6DoF (Dynamic mesh). But problem is that it fails when particles strike to each other.
June 29, 2013, 09:46 |
Rep Power: 14 |
I thought of using Dynamic mesh. But the issue is my particle diameter size to tube diameter size is 0.04. Also I have to simulate flow 8 particles and then go upto 100-200 particles.
June 29, 2013, 09:52 |
Answer
This is DPM limitation and you may have to neglect angular velocity.
Other problem is your rather big particles sizes. I mean particles with 4% size of characteristic length are rather big for Discrete Phase and can fully change flow pattern. You may switch to Eulerian method.
Rep Power: 14 |
Sadjad,
Do u think I should still go for dynamic mesh? |
June 29, 2013, 09:56 |
Rep Power: 14 |
Oh the size is big? I thought it is small. Because the references I am using they have the ratio of particle to tube diameter size higher than what I am trying to do. Thanks for your help brother.
December 26, 2013, 02:09 |
#9 |
Rodman
Rep Power: 12 |
Hi,friend. I want to simualte the movement of water droplet. If you konw how to control the velocity of the water droplet using the DPM model? I write an UDF about this, but it's incorrect, could you give me some suggestion?
#include "udf.h" #include "dpm.h" DEFINE_ADJUST(my_adjust,d) { Tracked_Particle *tp; cell_t c=P_CELL(tp); Thread *t=P_CELL_THREAD(tp); Particle *p; if(P_POS(p)[2]<14.8&&P_POS(p)[2]>=13.4) begin_particle_cell_loop(p,c,t) { P_VEL(p)[2] = -0.2; } end_particle_cell_loop(p,c,t) } "Uninitialized varible ’tp' used" and "Uninitialized varible ’p' used" appears when I compile the UDF. Thank you. |
forced to sticking of soot particle | kmgraju | CFX | 0 | November 27, 2012 09:08 |
particle velocity profile | mr3_player | FLUENT | 0 | October 8, 2012 15:33 |
angular velocity | learning_never_ends | FLUENT | 0 | June 30, 2008 17:04 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
particle velocity and velocity profile | HGG | FLUENT | 2 | June 10, 2001 16:32 |
