porou jump, permeability
Old   July 9, 2010, 09:33
Default porou jump, permeability
pertupd is on a distinguished road
Hy all,
I trying to set porous jump model in fluent to model 3D flow over perforated plate (cca, 10 mm in thickness).
I computed inertial resistance and face permeability according to fluent 6.3 User guide 7.19.6 paragraph based on tabulated values of delta pressure - velocity (dp-c) dependence. The dp-c was determined based on detail fluid flow over element of the perforated plate.
I approximated dp-c dependence by quadratic equation:
dp=a*c^2 + b*c
But the b coefficient is negative for my case and thus the permeability value (alfa) too.
Problem is that fluent does not accept negative value of alfa.
How to input the alfa?
if I thing that the model with dp=.. -b*c is different to the dp=.. +b*c.
By the way the value of alfa is rather small (of order of 1.e-7) - thus enhancing einfluence of inertial resistance.
Order of C2 (inertial resistance coefficient) is cca 500 for the plate.
Thanks.
pertupd is offline   Reply With Quote
Old   April 15, 2014, 23:52
will321321 is on a distinguished road
I am Having the same problem with the same procedure can someone please enlighten us.
thank you.
will321321 is offline   Reply With Quote
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
Pressure jump and momentum source Tanya FLUENT 1 June 4, 2009 15:22
Porous Jump Naresh FLUENT 0 April 25, 2007 15:36
correct assignment of permeability? jemteo CFX 0 March 17, 2006 05:34
Please Help ! Pressure Jump of Fan?? Boris FLUENT 0 January 28, 2003 20:26
