What's wrong? Non-conform mesh problem!!!
Old   July 17, 2003, 00:05
Default What's wrong? Non-conform mesh problem!!!
Neo
I have set all non-conform interface BC and could have a result.But when I left the fluent solver then start fluent again, I could read the .cas file that I saved before but when it "bulding grid" the error message appeared on control window as below:
Error: %si-create-grid-interface: wta(int) Error Object: (sb1-id . 6) . . . . . Error: inquire-adjacent-threads: wrong type argument[1] (thread) Error Object: 0 . .
Then I could't read .dat file that I saved before.
someone know what's wrong? Please give me a hand
Thanks all
Old   March 31, 2013, 15:00
Default fluent error
Ravi Jogi
jogiravi is on a distinguished road
I have same problem but could not get solution.
I have meshed centrifugal pump model in hypermesh 9. then meshed file is exported to gambit for boundary condition. And then simulated in fluent. Whole simulation completes. Then I closed fluent. Then again opened fluent and read case and data file. Now fluent shows error
I can not understand where the problem is. Is it in meshing or grid interface?
Waiting for the reply
jogiravi is offline   Reply With Quote
udf error srihari FLUENT 1 October 31, 2016 14:18
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Problem with Output to .cfx5 mesh Ben CFX 4 January 24, 2008 17:47
