fluent
Old   April 12, 2013, 14:10
Smile fluent
amel
amel is on a distinguished road
Dear All,
WHEN I export A MESH IN 3D gambit fluent DOC I HAVE THIS ERROR PLEASE HELP ME
Error: This appears to be a surface mesh.
Surface meshes cannot be read under the /file/read-case functionality.
Reading Cells: failed while reading section 12.
Clearing partially read grid.
Error: Read_Grid_Section: Aborted due to critical error.
amel is offline   Reply With Quote
Old   April 12, 2013, 15:15
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
It look that you changed the file type while you exporting it from Gambit be sure that you select solver as FLUENT 5/6 and rename your mesh file then export it again if Gambit wrote for you this message (your mesh file exported successfully) that's mean the mesh file become ready to use in FLUENT.
kbaker
Originally Posted by amel View Post
Dear All,
kbaker is offline   Reply With Quote
Old   April 13, 2013, 14:51
amel
kbaker
hello,
thank you
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
