February 28, 2013, 16:45 |
Bingham fluid parameters
Jan Stejskal
Rep Power: 13 |
Greetings!
I´m trying to simulate laminar flow of Bingham fluid in Fluent 12.1 by using Herschel - Bulkley model. I´ve got constants which are needed to define Bingham fluids parameters...binghams apparent viscosity and value of yield shear stress from experiment. But there is problem with "critical shear rate" column...I have no idea what should i type into this. Is there anyone whou could advice me? Thanks for every proposal! |
March 1, 2013, 15:43 |
Jan Stejskal
Rep Power: 13 |
No proposals from local experts?
April 17, 2013, 23:42 |
#3 | |
bruce
Rep Power: 13 |
April 18, 2013, 14:26 |
Jan Stejskal
Rep Power: 13 |
I´ve figured it out. Bingham fluid behaves like "solid" mass in area under critical shear rate. You should insert number near to zero to this column. I usualy insert 0,01 or 0,001 and it works pretty well.
April 19, 2013, 02:06 |
bruce
Rep Power: 13 |
Thank you mate. I found if the critical shear rate you input is too small, some numerical instability will occur, especially when the flow speed is very low. Anyway, I think this parameter is almost impossible to get from the lab test. The only way is to try different number and see if the simulation results have a good agreement with pratice. Keep changing it until it yields reasonable result.
apparent viscosity, bingham |
How to get Pro/E Parameters to Show Up | Trues | CFX | 4 | September 17, 2012 20:26 |
Questions of fluid pairs | fjalil | CFX | 1 | June 10, 2009 17:36 |
Fluid pairs | fjalil | Main CFD Forum | 0 | June 10, 2009 13:47 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
