Axial velocity problem in 2D axisymmetrical flow
Like Tree1Likes
  • 1 Post By flotus1
Old   March 11, 2013, 23:38
Default Axial velocity problem in 2D axisymmetrical flow
Musa
mozkan26 is on a distinguished road
Hi everyone,
I am simulating the flow over a rotating disk in 2D axisymmetrical geometry. The problem is that there is nearly no axial velocity occurs on the disk. Radial and swirl velocity components are fit completely with the data in literature (von Karman solution) but axial velocity component is too small. It cannot be even compared with the Karman solution. For example, it suppose to be about 100 unit but I report it about 1 unit. It is really weird when the other two components look perfect.
Can someone provide any explanation?
Many thanks in advance.
Musa
mozkan26 is offline   Reply With Quote
Old   March 12, 2013, 01:50
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
If you are willing to give some information about your setup, maybe someone can help.
flotus1 is offline   Reply With Quote
Old   March 12, 2013, 02:19
Musa
Well, the geometry is so simple as in attachment. Boundary conditions are as follows;
Disk: moving wall, constant rotation speed, no slip
Walls: no shear stress
Velocity inlet: radial and swirl components are zero and the axial velocity gradient in z direction (axis direction) is zero.
Velocity inlet boundary at top was wall at first and I got the same weird results for axial velocities. I decided to change it to zero gradient condition but it didn't affect results much.
Velocities are read at created points in domain with 'vertex average' choice.
Radial and swirl components are perfect but there is a problem with axial.
Many thanks!
Old   March 12, 2013, 03:55
flotus1's Avatar
Alex
Since you have no outlet in your domain, I dont see how an axial veloxity could be established.
The fluid simply has no way to go.
Maybe the right wall is supposed to be some kind of outlet in the benchmark you are comparing your data to?
stuart23 likes this.
Old   March 12, 2013, 07:03
Musa
Dear Alex,
Thank you very much for your suggestion. Actually because of centrifugal force created by disk rotation, there should be a suction over the disk towards disk surface. This model is a water tank and the rotating disk is mounted at the bottom of this tank. This is a usual experimental rig in literature for rotating disks which hasn't got any inlet or outlet. Fluid is supposed to be circulated in tank with coming towards the disk and centrifugal force pushes it out above the disk and so on. I did try your suggestion anyway but the result hasn't been changed.
The problem can be reporting the results, I guess, but not sure really. Since two velocity components are fit very well the last component should be fit for momentum conservation. I mean there may be an axial flow in my solution which I cannot succeed to see in 2D axisymmetric swirl domain. Is this possible?
Old   March 12, 2013, 07:23
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Musa,
Alex is right, I think you need to check the underlying physics you are trying to model.
There is something fundamentally wrong in your simulation because if you have one inlet and no outlet, d(rho)/dt > 0. So as t->infinity, your vessel will turn into a black-hole....
Stu
stuart23 is offline   Reply With Quote
Old   March 12, 2013, 07:34
Musa
Thanks Stuart, you are both absolutely right. But what I am telling is that the results are not changed in these conditions:
1st try: there is neither inlet nor outlet, all are wall except axis.
2nd try: top is inlet, others are wall.
3rd try: top is inlet, side is outlet.
In other words, I do not have any inflow or outflow (they are really small, I can say zero!) even though I define the boundary layers as inlet and outlet.
Old   March 12, 2013, 07:39
Stuart Buckingham
Musa,
How do you get axial velocity at the disk then? Wouldn't the axial vector be pointing through the disk?
Stu
Old   March 12, 2013, 07:44
Musa
Dear Stuart,
I am reading all the velocity components at several created points just above the disk, in the boundary layer. How can we explain fundamentally, if two velocity components (radial, azimuthal) are totally perfect in this boundary layer, why there is nearly no third (axial) velocity component?
Musa
Old   March 12, 2013, 07:52
Stuart Buckingham
It depends where the point is in your geometry. This could be a mesh refinement issue...? Are you using wall functions?
Stu
Old   March 12, 2013, 07:57
flotus1's Avatar
Alex
Are you really sure about the position of the monitor points? The axial velocity is supposed to be zero in the vicinity of the wall.
This could explain why the values you get are too low.
The mesh resolution is another issue, especially since the monitor points in fluent are vertex-averaged.
Another boundary condition worth trying is a pressure inlet at the top boundary.
Musa
Basically, this means that the velocity field is not divergence-free. My first guess is that the solution is not converged.
Old   March 12, 2013, 08:05
Musa
My viscous model is laminar and I am using very fine boundary layer mesh (there are 20 cells inside the boundary layer thickness, which is known theoretically). I have 45 points above the disk from the disk surface to 10 times BL thickness. I thought as Alex said near the disk axial flow getting closer to zero and I plotted the axial velocity component on a line which is between disk surface to upper boundary in whole domain but still I read silly values in that xy plot. Also vector plotting in this 2D plain doesn't show really a 'strong' axial vector. I can see the flow coming towards the disk but the values are just funny.
Old   March 12, 2013, 08:07
Musa
It is converging finely.
Old   March 12, 2013, 08:47
flotus1's Avatar
Alex
Do you trust the axisymetric swirl model in fluent? Maybe it is a good idea to set up the case in 3D.
Old   March 12, 2013, 08:52
Musa
In this case I can't I am afraid. I've been struggling with this problem for about a week and it drives me crazy If the other two component were look like a disaster, I wouldn't keep trying. I could say easily this solution is rubbish. But in this case it is difficult to make any comment. I should try 3D case and see what will happen. Thank you very much again for all of your replies and time you spent for me.
Musa
Old   March 12, 2013, 12:37
flotus1's Avatar
Alex
Many thanks!
I hope the axis is the z-direction only in your drawings.
In Fluent, the axis in an axisymetric case HAS TO BE the x-axis.
Different topic: Would you mind telling me how you created a velocity-gradient boundary condition in Fluent?
Old   March 12, 2013, 12:44
Musa
Yes, it is just in drawings. Axis in simulations is x-axis, I know that.
I created velocity-gradient (zero gradient) with a udf which looks like this;
#include "udf.h"
DEFINE_PROFILE(axialVelocity,t,i)
real xf[ND_ND], xc[ND_ND];
face_t f;
cell_t c0;
Thread*t0;
begin_f_loop(f,t)
F_CENTROID(xf,f,t);
c0=F_C0(f,t);
t0=THREAD_T0(t);
C_CENTROID(xc,c0,t0);
F_PROFILE(f,t,i)=C_U(c0,t0);
end_f_loop(f,t)
Old   March 14, 2013, 18:22
Musa
Oh dear!!!
I found my mistake, there is nothing about Fluent/simulation. It is about the scale of data which I compared. I nondimesionalized velocity components with dividing (rotation speed*radius) but only for axial one, I also need to multiply this nondimensional velocity with Reynolds. Now the axial profile looks fine too. Simulation works very well actually, sorry again for taking your time.
Musa
Old   April 23, 2013, 12:57
john chant
john c is on a distinguished road
Musa
Musa, did you ever get around to doing the 3-d version of this case? I am doing something very similar and having a bit of an issue defining/figuring out my boundary layer. I have rotational flow inside of a geometry that is defined to be air, I am trying to find the boundary layer created around the disk, should I just create some points and then bring them closer and closer to the geometry until the velocity no longer changes significantly?
john c is offline   Reply With Quote
Old   April 28, 2013, 13:06
Musa
Hi John, I didn't try 3-d, after I found my problem. If you are asking the boundary layer thickness above the disk, theoretical thickness in the literature is 5.5*sqrt(kinematic viscosity of fluid/rotational speed).
And yes, you can see that boundary layer thickness with creating points above the disk and plotting the swirl component of velocity from these points (as I did and saw the theoretical thickness in my case.)
Problem with time average tangential velocity in swirl flow. lakhi FLUENT 5 July 18, 2012 16:28
Problem with velocity values - flow through diffuser karthikn21590 FLUENT 0 March 5, 2012 13:43
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 16:10
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
axial velocity profile in swirling flow David FLUENT 0 March 15, 2004 08:39
