interface shadow missing
Old   April 24, 2013, 15:36
Question interface shadow missing
Lagunesvary
chinna is on a distinguished road
Hai,Im doing heat transfer simulation using Fluent. Recently Im facing a problem, where the interface shadow will be missing when i close the fluent setup and reopen it. the interiors and the new walls with the Id, which are created along with the interface shadow are there. is there any solution for this???
every time i wanted to edit or reopen the fluent setup, i`ve to reset the setup to proceed. it`s really taking all my times. please help me with this. thank you
chinna is offline   Reply With Quote
Old   April 25, 2013, 06:33
Paritosh Vasava
vasava will become famous soon enough
Are you using Gambit or Ansys Meshing for generating mesh?
vasava is offline   Reply With Quote
Old   April 25, 2013, 15:16
Lagunesvary
Ansys workbench meshing... the interface become interior...i tried to change to back but failed...
Old   April 26, 2013, 02:28
Paritosh Vasava
Interface becomes interior if both the domains are of fluid. In ansys meshing by default every domain is solid. But you have option to declare if the domain is 'solid' or 'fluid'. After you do so, you need to make the interface again. You can right click on the interface and select 'generate interface automatically'.
This should work for you.
Old   April 29, 2013, 01:39
Lagunesvary
yes both domain are fluids but i declare it as fluid before i mesh. everything fine at the first time simulation. however if i close the fluent and reopen it. the interfaced zone missing and new zone(interior) created. i tried to make interface again but i`m failed. and i coouldn`t find the option 'generate interface automatically'.
Old   April 29, 2013, 01:56
Paritosh Vasava
One more question: Are you using Workbench to generate mesh then export it to fluent (for setting up case)? Or you use workbench for entire procedure?
Old   April 29, 2013, 02:00
Lagunesvary
im using workbench for the entire procedure... im doing fluent setup through workbench...
Old   April 29, 2013, 03:03
Paritosh Vasava
Sorry but now I do not have any suggestion for you except that you do the meshing and fluent setup separately.
I have had my own issues with workbench and then I realized that it is better to do it the old way.
Old   April 29, 2013, 03:22
Lagunesvary
ok.. but i dont know how to do it separately...should i mesh my geometry in workbench and save it. then i open fluent separately and import the meshed geometry there. is that how it`s work??
Old   April 29, 2013, 03:26
Lagunesvary
i just notice there are few applications under ansys meshing : ICEM CFD 14.0 , TGRID 14.0 nad TurboGrid 14.0 ... should i use any of this meshing ad
Old   April 29, 2013, 04:42
Paritosh Vasava
I have no experience with any of them so no comments. But I think Ansys meshing is good enough for your application.
Old   April 29, 2013, 04:45
Paritosh Vasava
You can make mesh as you use to do earlier. Then export the mesh in .msh format. Start fluent separately (not from workbench), read mesh and continue from there.
Old   April 29, 2013, 07:37
Lagunesvary
ok..thank you.. i`ll try
Old   April 29, 2013, 09:33
Lagunesvary
it`s working..thank you
im bit curious about the time step setup..if you dont mind...
i planing on simulating heat transfer for 10min, ..etc. im wondering how to fill up the values for time step size and number of time steps...
this is how i fill them up : time step * number of time step = 10min * 60 sec
is it correct??
interface
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
