Erosion modelling in slurry flow through pipelines |
May 1, 2013, 04:40 |
piyush singh
I have already explored the option to solve erosion model and also solved the erosion rate on a nozzle of 3.6mm inlet dia and 0.8 mm of outlet dia. Now i am working on a model that is a big container of inlet dia 250 mm and 31 mm but i am not getting the result though i am solving it with same procedure. I want to ask is there any changes required in erosion modelling procedure or the values that i am taking if the inlet and outlet size increases suddenly like in this case.
thanks |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Models for Erosion in Slurry Pipe | leonozx | FLUENT | 1 | May 25, 2011 10:28 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
modelling blood flow in arteries with starcd | sara | Siemens | 5 | April 10, 2007 09:17 |
Modelling flow around a ship's hull using vof | Manoj Kumar | FLUENT | 0 | February 26, 2005 16:22 |
