Conjugate heat transfer problem
Old   May 5, 2013, 21:14
Default Conjugate heat transfer problem
Engineer4 is on a distinguished road
I'm a beginner to CFD and trying to do a problem that involves a duct of size 160mm outside dia, 158.7mm inside dia. Air travelling through at a speed of 4m/s and a temperature of 293.75K. I need to find the heat transferred to the duct. I have the geometry and mesh fine. I think there is something wrong in the conditions I am setting as the solution keeps diverging. I set the energy equation to on, and put flow is laminar. I then set the speed and temperature of the velocity inlet, and the back flow temperature of the pressure outlet. Change the walls to 'convection' for thermal with the heat transfer coefficient for the metal that is being used and the wall thickness as 1.3mm. Using green-gauss node based and 200 iterations and ANSYS does the rest... But something's not right.
Any help would be appreciated.
Thanks.
Engineer4 is offline   Reply With Quote
Mesh suggestions for a conjugate heat transfer problem maddalena Main CFD Forum 1 January 25, 2013 17:39
Conjugate heat transfer ali_1364reza CFX 3 May 30, 2012 07:42
Conjugate heat transfer kiteguru CFX 2 January 9, 2012 15:57
Heat transfer problem seojaho CFX 6 May 6, 2010 00:32
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
