two airfoil elements
Old   May 9, 2013, 04:27
Default two airfoil elements
ashish
Ashish22 is on a distinguished road
hi
i am doing numerical analysis of two airfoils separated by distance
i got results for 2 cases, both airfoils have same dimensions...
case 1 airfoils separated by dist. 100 mm
case 2 airfoils separated by dist. 400 mm
in case 1 lower airfoil generate much higher lift (.192) compare to lower airfoil in case 2 (0.08)
lift generated by upper airfoil is approximately same for both cases
i am adding pressure contours for both case
please someone explain the reasons
Ashish22 is offline   Reply With Quote
Old   May 9, 2013, 08:25
Lefteris
Aeronautics El. K. is on a distinguished road
This happens because of the aerodynamic interraction between the airfoils. You should be expecting something like this to happen.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   June 8, 2013, 07:08
ali
sorkhani is on a distinguished road
by adding an airfoil above another, the velocity between two airfoil (above the lower airfoil) has been increased, therefor the pressure will be decreased and lift force will be increased.
by decreasing the distance between two airfoils the Phenomenon will be intensified.
sorkhani is offline   Reply With Quote
[ICEM] Meshing an airfoil using C grid, some curves have no elements tmartin ANSYS Meshing & Geometry 3 November 16, 2011 19:58
[CFX,ICEM] Simulation of wing / airfoil profile - pyramid elements, angle of attack Jonas_mm ANSYS 2 November 4, 2011 04:26
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 09:06
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
