shell conduction usage in FLUENT
Old   May 13, 2013, 11:39
Smile shell conduction usage in FLUENT
CFD User
kbhamidipa3 is on a distinguished road
I am trying to model heat transfer in a battery pack. The pack consists of some cells and each cell is separated by a 1 mm thick mica insulation. The cell width is about 30 times higher than this thickness. I simulated two cases keeping everything the same except the following;
1. I included 1 mm mica as part of the domain separating every cell in the first case
2. I am capturing the mica spacing and its thermal resistance using shell conduction in the second case. I identified the end cell faces as walls and checked shell-conduction and specified 0.001 m for thickness.
My understanding from reading FLUENT manual is that there should be no difference whether we take path 1 or path 2. However, when I compared the cell temperatures at the end of simulation, the differences in the temperatures are higher when mica is included in the domain versus simulation using shell conduction. In other words, when actual mica was included, it seems to be capturing additional thermal resistance. I am unable to understand the reason for this discrepancy. Any help with this situation is greatly appreciated.
kbhamidipa3 is offline   Reply With Quote
shell conduction setup chinna FLUENT 15 May 5, 2013 09:26
shell conduction modeling tmeysam92 FLUENT 0 May 1, 2013 06:11
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
fluent usage for Ventricle problem meena FLUENT 1 June 30, 2009 16:22
I want to learn UDF usage in Fluent sangamnath FLUENT 5 December 17, 2005 12:16
