May 17, 2013, 01:14 |
What's delta x plus?
Now I am reading the user's guide of ANSYS FLUENT 14.5, for some criteria about mesh generation which is for LES simulation. It mentions, "it is typically recommended to use a mesh with a grid spacing scaling with delta x+ =40, delta y+=1, delta z+=20, where x is the streamwise, y the wall normal and z the spanwise direction (for example, channel flow)." in page 694. I have no idea about " dleta x +", and what's the difference between "delta y+" and "y+"? Any suggestion will be greatly appreciated. Thanks in advance. |
May 17, 2013, 01:52 |
Philipp
Rep Power: 26 |
What they mean is:
delta x+ = x+ delta y+ = y+ delta z+ = z+ But this is a frowzy formulation... Edit: And x+ is the wall spacing in x direction and is normalized on the same physical value as y+. The same for z+.
The skeleton ran out of shampoo in the shower. Last edited by RodriguezFatz; May 17, 2013 at 03:07. |
May 17, 2013, 03:45 |
#3 | |
is : all the variable with a plus is derived from similar formula; delta means space between any two adjoin meshlayer; and without delta, it means space between the first mesh layer and the wall. However, I'm not sure if it is correct. |
May 17, 2013, 05:23 |
Philipp
Rep Power: 26 |
Yes, you are right, this is a better explanation.
But, saying y+ is located at the first grid point (what nearly everyone does), is pretty inaccurately anyway, since y+ is a normalized variable calculated by the physical "y". So basically you can use any "y" value to calculate a related "y+" value. The common usage seems to be pretty much slang.
The skeleton ran out of shampoo in the shower. |
x plus |
how to extract the LES filter delta in creatField.H | hz283 | OpenFOAM | 1 | November 22, 2022 14:30 |
Delta wing cfd | H_R | FLUENT | 16 | September 19, 2013 04:41 |
[GAMBIT] Need help with meshing 3D Delta wing | tuantran | ANSYS Meshing & Geometry | 22 | September 17, 2012 07:00 |
Please help How is delta t determined in interFoam | Pei-Ying Hsieh (Hsieh) | OpenFOAM Running, Solving & CFD | 16 | November 23, 2005 10:06 |
Delta Wing Structured Grid | Riaan | FLUENT | 3 | December 31, 2004 12:03 |
