how to change the y+ value
HI,
I need to change the y+ value more smaller, how could I do it? Thanks in advance |
Place the first grid point closer to the surface
Dear Lefteris,
thanks for your quick reply, do you mean I need to minimize the spacing of the edage which is near the wall? And when I adapt the y+value, and set the value, but when I xy-plot it, it is still larger than 1. Do you know why? |
Yeap, minimise this edge by placing the first grid point as close to the wall as possible (as close as you need actually).
I don't really understand what you mean when you say "when I xy-plot it" (you mean you plot y+ ?) but y+ depends upon other parameters as well which you can only estimate beforehand and know their value only after the computations are completed. |
Do I need to creat a iso-surface that near the wall, or just choose the wall surface? If I need, which one do I need to keep surface constant? One more problem, we have been a experimental data to compare, but the velocity from the xy-plot are not very close to the experimental one. Do you kown why? Best regards |
If y+ = 9 and you want it to become y+=1 you need to make the first cell about 9 times finer than in your current grid.
In Fluent, you just need to plot y+ on the surface. It will use the first cell height for that! For the last question you need to show us more about your setup / grid / settings and so on. |
IS that mean I need to refine it in ICEM in 'refinement'-level 9? IS that right? or need to minimize spacing 9 times smaller |
I am not sure what "refinement level 9" means. But if your first cell height is 1mm now, you need to reduce it to about 0.11mm.
y+
hi
change your mesh near the wall as small as you can and after check this parameter. |
hi
use this tool to specify your mesh geometric parameters before your first calculation ,and i think there isn't an effective way to adjust your mesh (all y plus values) to the just condition. http://geolab.larc.nasa.gov/APPS/YPlus/ |
