Compute the power of small wind turbine.
Old   October 31, 2005, 09:10
Default Compute the power of small wind turbine.
Luolin
Hi, Please someone gives me some advice about wind turbine computation. I am computing the power output of small wind turbine using Fluent, and has the results. I am confused about how to get the power. Since the power of the wind turbine is equal to the torque timing the rotational speed. I used the report moment to get the power. the power=moment*rotation speed. Is the moment is the same with the torque forced on the blades? I think I set the right center of the axis for the moment. It seems the moment includes the pressure and viscous moment. So I got the total moment. the value is 2.8nm. But it is too big than what I imagined. Is the method to compute the power right? or should I refine the mesh to have futher computation?
Old   October 31, 2005, 09:17
Default Re: Compute the power of small wind turbine.
Luolin
thanks.
Old   October 31, 2005, 12:07
Luolin
If I changed the reference value of the pressure, the total moment is also changed. what pressure should I use for my computation?
thanks.
Old   October 31, 2005, 13:32
Luolin
it seems the computing of pressure force will use the reference pressure. so the pressure moment will also change with the pressure force and the reference pressure in the reference value. so what reference pressure should I select in the reference values?
thanks.
Old   November 2, 2005, 08:51
Luolin
I fixed my problem. My situation and my model are complicated. In brief I enlarged my domain to three blades. And remesh the domain, and boundary layers, and defined the surfaces of the blades as a whole wall. then compute the moment from the report. It is approaching the right data from the test.
Old   June 17, 2010, 07:06
tom
caohan is on a distinguished road
Originally Posted by Luolin
;125758
Hi Luolin,
Can I ask you a question, I am doing the same project with you, also, my result is too big by comparing with the experimental data. do you know how to solve the problem. normally, it is a 10kw wind turbine, after finish the simulation, the result is over 200 kw which is unacceptable. I don't know how to approach to the right data. hope you can give me some tips.
Thank you
Regards
Han
caohan is offline   Reply With Quote
Old   June 17, 2010, 10:29
kdrbrk's Avatar
Burak
kdrbrk is on a distinguished road
it has been five years, and there is no info about him/her like:
caohan
tom
I guess he/she is not here anymore...
kdrbrk is offline   Reply With Quote
Old   June 17, 2010, 13:32
tom
caohan
tom
haha, I think so, wish he/she can come here again!!
Old   June 18, 2010, 01:31
kdrbrk's Avatar
Burak
I am not so sure, he/she asked a question and answered himself/herself 4 times
No one ever dared to answer him/her
Old   May 27, 2013, 14:52
niloogh is on a distinguished road
Originally Posted by caohan View Post
Hi Luolin,
Thank you
Regards
Han
hi caohan
i have the same problem as you;big amount of torques which make unacceptable power output.
what can i do to fix it??
would you plz help me?
niloogh is offline   Reply With Quote
Ducted wind turbine (BC for the shroud) Pepita CFX 4 June 29, 2013 07:09
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
Tip speed, RPM, Power, Wind Speed relationships nabilzhafri Main CFD Forum 0 July 22, 2010 11:28
Wind Power Frank Grassi FLUENT 0 October 12, 2007 11:20
about wind turbine power prediction with cfd windman FLUENT 1 January 11, 2007 06:41
