May 20, 2013, 23:42 |
FLUENT Problem
Rep Power: 13 |
I did a mesh check in FLUENT and received the error "symmetry zone 54 has two adjacent cell zones." What does two adjacent cell zones mean? I tried searching for this error to no luck.
May 21, 2013, 05:35 |
OJ
Rep Power: 20 |
I think you have fluid zone (or domains) at both the sides of symmetry, making symmetry as an internal face, or interface between two domains, which is not allowed. Try correcting your model by deleting the fluid zone at one side of symmetry or specify the symmetry such that it doesn't have any zone at the other side.
OJ |
May 21, 2013, 15:34 |
#3 | |
Rep Power: 13 |
May 21, 2013, 15:40 |
OJ
Rep Power: 20 |
Why do you need the fluid domain at both the sides of symmetry? symmetry is used so that you don't have to use a full geometry but only half one, because the flow structure in the other half is exactly mirror image of the one you are simulating! Remove the domain at one side of the symmetry, otherwise you won't be able to simulate.
OJ |
May 21, 2013, 15:46 |
#5 | |
Rep Power: 13 |
If we're thinking of the same thing, then I may have already removed it in design modeler with the symmetry feature. I attached an image of what I mean. Red is my symmetry surface. Not sure if this matters, but i tried simulating yesterday without solving that error and the solutions started diverging at about 30 iterations. Would this kind of error affect convergence? Thanks! Last edited by pyroknife; May 22, 2013 at 14:58. |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
[ICEM] ICEM CFD boundary conditions conversion to Fluent problem | kalyangoparaju | ANSYS Meshing & Geometry | 0 | October 30, 2011 23:40 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
Fluent boundary conditions problem | bobo | FLUENT | 2 | July 3, 2009 06:28 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
