June 7, 2013, 09:59 |
Understanding Radiation
Rep Power: 12 |
Hi All! I am working on a CFD simulation with radiation implementation. The model I used mostly is the DO model with high angular discretization (say, 25 titah and 25 phi) and fine pixels too (say, 9 x 9). (3D problem with semi-transparent walls)
It took awhile to figure out how to properly set up a radiation problem but I believe I have understood and mastered that . Now, my question is to do with the results. In the simulation result, one of the result I have access to is: Incident Radiation with units (W/m2). http://www.sharcnet.ca/Software/Flue...ug/node984.htm (31.4-21) My question is: Why are the units for Incident Radiation (W/m2) when the equation in the link is clearly just W. Can I hand calculate the Incident Radiation so I can compare theorectical background with Fluent results? (I have made quite a few tries but none successful ) Thx for reading. |
June 12, 2013, 05:21 |
Rami Ben-Zvi
Rep Power: 17 |
Although your query is specific to Fluent (and better be posted in the Fluent forum), the Eq. (31.4-21) you cite is the explanation: The intensity I integrated over the whole solid angle w results in W/m^2 as the units of the incident radiation, G.
June 12, 2013, 09:46 |
Rep Power: 12 |
Thanks for your reply. I will try to move this discussion over to the appropriate forum as soon as I figure that out. Thanks. Back to the query.
I am unsure of what Fluent considers intensity, I as. From my understanding of intensity; it is defined as power per steradian (solid angle) and doesn't change with distance from source/antenna. Therefore, it should have units of (W/sr) and after integrating with a range of solid angles, should result in simply (W). I am aware however, there is fragmentation in definitions of intensity in the world of "optics" so I looked up Wikipedia to gain a better understanding. http://en.wikipedia.org/wiki/Radiation_intensity http://en.wikipedia.org/wiki/Power_density http://en.wikipedia.org/wiki/Solid_angle According to Wikipedia, radiation intensity is the power density per solid angle. This confuses me even more because if so, the units will be (W/m^3) * (m^2) = (W/m??) I know I am not an expert in this topic so please be patient with me Thanks for any help and feedback. |
June 16, 2013, 04:51 |
Rami Ben-Zvi
Rep Power: 17 |
The intensity, I, is defined (see e.g., Modest or Siegel and Howell or Sparrow books) as the power per area normal to rays per steradian, and its units are therefore W / (m^2 * sr).
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
Surface incident radiation | Pipiola | FLUENT | 0 | August 11, 2009 15:46 |
Multiphase radiation in CFX | Luk_Fiz | CFX | 5 | March 17, 2009 03:51 |
Radiation: definitions | visatron | CFX | 7 | January 8, 2004 15:25 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 05:56 |
