Some questions concerning direct Aeroacoustical simulations using Fluent |
June 10, 2013, 05:17 |
Rep Power: 12 |
Hello everybody,
I'm a beginner user of Fluent, and I have to perform some aeroacoustical calculations, so I would be very grateful if someone could help me. I'm studying jet noise produced by an in-duct hot (90 degrees Celsius) air injector. A mesh of the injector has already been done for aerodynamic calculations. And I want to use this model to do direct aeroacoustical calculations. 1) Is it ok to use the same mesh? 2) After a lot of research, I think I determined the solver and solution method to use, but I would like to confirm this with a more experienced user. So I'm doing a -Transient simulation -SAS model or LES model -Acoustic FWH model on (source: injector, and 3 receivers spread arround the source (inside and outside the source surface) -Using a density based explicit solver -ROE-FDS flux -CFL=1 -How can I determine the timestep and the number of timesteps? -I used the BCs used for the aerodynamic simulation Thank you very much in advance for your replies. Good day to all |
June 14, 2013, 07:50 |
Rep Power: 12 |
Anyone??? I really need help here!
June 16, 2013, 07:00 |
Rep Power: 12 |
June 18, 2013, 02:39 |
Rep Power: 12 |
Thank you for your answer, it's a good tutorial. However I still need an answer to my questions...
aeroacoustics, convergence, fluent, transient simulation |
Question about transiet simulations in Fluent | Vitaly | FLUENT | 5 | February 19, 2012 22:06 |
Help,I have some questions about UDF of mass diffusivity in fluent | apolloking | Fluent UDF and Scheme Programming | 0 | March 20, 2011 11:40 |
CFD beginner:- Help needed, general questions on Free jets? (Fluent 5.2.3) | Wong, R.Y.T. | Main CFD Forum | 5 | October 22, 2010 00:51 |
The Questions about Reporting correlations in fluent mixsim | xiqiu | FLUENT | 0 | October 25, 2009 20:43 |
FLUENT + QUESTIONS | kospan | Main CFD Forum | 4 | July 30, 2008 16:30 |
