ANSYS Fluent Run
Old   June 30, 2013, 12:43
Question ANSYS Fluent Run
Sa.Baraty
sara22 is on a distinguished road
Hi All.
i want to run many mesh files.how i can adjust ansys fluent that automatically run all my case file subsequently?
please help me.
sara22 is offline   Reply With Quote
Old   June 30, 2013, 21:02
Christopher Hershey
Hershey is on a distinguished road
A journal file would probably be the best bet. Do you have experience with them? They are essentially a set of instructions that are read in by Fluent and will actually set up the problem and run the case with only a few lines of text.
However, do you know if these cases you want to run are actually going to work? If you set up several cases to run one after the other then it might fail if there are errors that pop up.
If you give me more information on what you are looking to do, then I can probably help you out. Are you starting from scratch or do you have case files already saved and ready to be started?
Hershey is offline   Reply With Quote
GPU acceleration on ANSYS Fluent 14.5 Daveo643 FLUENT 20 April 28, 2018 13:50
Fluent v6.3.26 better than Ansys v12.1 jemyungcha FLUENT 2 August 24, 2012 23:10
Loading of Temperature datas from ansys to fluent! need help!! tensun FLUENT 0 November 6, 2010 00:35
Hardware for running ANSYS Fluent 12.1 ngj_22 Hardware 2 September 29, 2010 07:26
export data from fluent to ansys galapago FLUENT 0 August 4, 2010 14:04
