Run
Old   July 4, 2013, 01:23
Exclamation Run
Sa.Baraty
sara22 is on a distinguished road
Hi All.
i want to run many mesh files.how i can adjust ansys fluent that automatically run all my case file subsequently?
please help me.
thanks
sara22 is offline   Reply With Quote
Old   July 4, 2013, 01:45
blackmask will become famous soon enough
Suppose you have a case file named 'runa.cas', you can save the settings for this case with the text command
/file/write-settings "run.settings"
Then you could write a journal file, which looks like
/file/set-batch-options no yes no
/file/read-case "runb.msh"
/file/read-settings "run.settings"
/solve/initialize/initialize-flow
/solve/iterate 1000
/file/write-case-data "runb.gz"
/file/read-case "runc.msh"
/solve/iterate 1000
/file/write-case-data "runc.gz"
Of course you could use an equivalent scheme script to do the loop.
I assume that your FLUENT version is new enough to accept the
text command.
blackmask is offline   Reply With Quote
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 19:44
Batch Run with Initial values file krrishcfd CFX 1 July 28, 2011 02:35
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
How to run and save tranisent case on Cray XD1 Leon FLUENT 0 October 3, 2006 21:59
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
