Pressure Drop calculation
Hi all,
I am little bit confused in setting up problem for pressure drop calculation in Fluent. I am using Ansys Fluent 13.0 :confused: Can anyone please help me out in choosing the correct boundary condition. |
what do you want to simulate? Messure the pressure drop between two parts of a pipe?
Yes I want to simulate the pressure drop in a pipe
the easiest way is to set to monitors at the reference Areas. If both outputs are set to statistic pressure the difference is your drop pressure.
If the simulation is alreaddy done you can use the report function |
Doubt I have is in setting up the problem.
Suppose we chose velocity inlet boundary condition at inlet and pressure-outlet condition at outlet. Suppose pipe is open to atmosphere we chose 0 pa for gauge pressure at outlet or if we have any other value measured by pressure transducer experimentally. Now here my doubt arises. Since we already fixed the pressure value at outlet then what is the meaning of pressure drop??? I am saying anything foolish please pardon me and explain me the correct version. thanks |
okay. You have a open channel flow and don't know your exact outflow pressure. You may use the outfow boundary condition (Guide 7.3.10). This is a condition for unknown outflow pressure and velocity. It isn't awailable for every setting, you need to check the case in this chapture.
That's the problem. Actually I am trying to model multiphase flow (solid-gas) in pipe. I am using eularian model for it. But according to fluent user guide outflow boundary condition is not compatible with eularian multiphase model. I have the values at inlet but I don't have any values for outlet. Although I can theoretically calculate the value of pressure drop from empirical relations available in various literature. From this I can get the pressure value at outlet and put it in fluent.
Then things come in my mind that why I am doing simulation for pressure drop in fluent when i am using empirical relations. |
It might be okay if you set the pressure outlet to a reference value (1 bar) and solve what pressure the project needs to realise your inlet velocity. If you take the diference between Inlet and Outlet pressure this should work too.
Ok..
Do you have any idea what will happen if I use outflow boundary condition at the outlet for eularian multiphase flow?? I have some published research papers in which author has used outflow boundary condition for eularian multiphase simulation. I can share those with you if you want.. |
If got Answer Please send me detils i m having same problem
As I m also doing same type of Problem but I stucked and if got solution then Please send me
nikhilchotai@gmail.com Thank you |
pressure drop in a channel using periodic boundary condition
hello every one:
I am simulating air flow in a channel using periodic BC in fluent: I need to calculate pressure drop to calculate friction factor in my channel. the air enters the channel with 0.3 Mpa pressure. now the question is : How can I calculate pressure drop across the length of a periodic duct?:confused::confused::confused: I t is really urgent if anyone can help me I will be really greatful:):):) |
