Jad
Rep Power: 14 ![]() |
Hi everyone,
I'm running a 2D transient simulation for a vertical axis wind turbine, and every time I create a "filled" animation for the contours of vorticity or pressure, the system tells me it has low virtual memory and crashes, despite my computer having 24Gb of Ram. Is that normal? Or am I missing something? I was thinking it might be because the animation is being plotted "live" as the solver is working, do you know if there is a way to write it to a file without plotting it live? Thanks for your help! |
Jad
Hi Far, thanks for the rep.
Yes I have over 1TB of free space so it's certainly not the issue... It's definitely a ram issue, when i look at processes in the task manager i see fluent using 23gb out of the 24gb of ram available... |
Jad
Yes that's what i thought, but i don't know how to set it up without the real-time animation... any hints?
Display Modes | |
number of iterations to converge solution in Fluent as Ansys Workbench output param | nnvoro | FLUENT | 4 | May 2, 2013 01:18 |
Discussion: Solution steering in Fluent | micro11sl | FLUENT | 1 | January 29, 2013 09:13 |
fluent 13 export solution data | Zyryx | FLUENT | 1 | November 11, 2011 10:09 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 07:51 |
Fluent Export Command Issue .... | Leo Hindarto | FLUENT | 0 | January 3, 2009 23:20 |
