Need help with irregular surface values
Old   August 5, 2013, 13:43
Default Need help with irregular surface values
highhopes is on a distinguished road
Dear Fluent users,
Simple question, why do you think there are irregular pressure values on the surfaces in the pictures below?
Using RNG, enhanced wall treatment with yplus 1, tried second and third order schemes, constructed a block structured mesh and generated geometry using icem cfd.
Sorry for posting the message on this board because I had posted the same on the main cfd forum. This might be the right board for it. I could not delete the previous one.
highhopes is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 01:44
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
Heat flux on a irregular surface massimo Siemens 5 December 11, 2002 05:55
