Temperature inside thickness of a tube using ANSYS Fluent
Old   July 31, 2013, 09:36
Smile Temperature inside thickness of a tube using ANSYS Fluent
Nikhil S
nandu6630 is on a distinguished road
Hi
I have a series of tubes branching from a header, where water at 250 deg C flows through the inside and flue gas at 600 deg C outside.The tubes are bent in nature and has a dimension of D60x10mm, and a length of 20 Metre. Some portion of the tube is insulated also. I need to find out the temperature profile inside the thickness of tubes as I want to input them for finding thermal expansion. How to model this problem, and can any one give me a detailed procedure to do the analysis?
I need to know, how to formulate the problem in CFD and the boundary conditions, I need to specify.. Pls send me a tutorial or sample problem
nandu6630 is offline   Reply With Quote
fluent, heat transfer modelling, tube bank, wall thickness
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
Free stream temperature in tube wall saharesobh FLUENT 2 November 19, 2012 08:32
gambit in Ansys FLuent 13 saharesobh FLUENT 0 August 1, 2012 16:30
liquid temperature at tube outlet? phsieh2005 Main CFD Forum 0 October 11, 2010 21:33
HELP!:CFD modelling using FLUENT in swimming pool Tee Main CFD Forum 0 September 7, 2005 21:48
