July 4, 2014, 11:40 |
Reference values and operating conditions
Rep Power: 17 |
I see that Ansys Fluent has reference values and also operating conditions. Could someone please explain the purpose of these reference values.
Is it required to change these reference values I mean for instance do I need to input density, viscosity of a fluid at a mean temperature in the domain in the reference value settings (or) is it fine to leave the reference values to some defaults
Best regards, Santhosh. |
July 7, 2014, 03:34 |
Alex
Rep Power: 46 |
The reference values do not influence the numerical solution in fluent.
They are only used for computing coefficients like lift or drag coefficient. The operating conditions on the other hand can have an influence on the numerical solution, depending on the setup. |
November 23, 2014, 04:58 |
#3 | |
Rep Power: 12 |
ı try to model melting/solidification for phase change material in enclosure. so thermophysical properties are depend on temperature. ı mean ı have values both solid and liquid phase (for cp, k). also ı have udf for density that depend on temperature. my question what should be operating temperature for this case. my initial temperature for phase change material is 300K. operating temperature shold be 300 or not. ı am confisued. thanks for your help. |
November 25, 2014, 09:51 |
Lucky
Rep Power: 65 |
There is only an operating pressure. Where do you see the operating temperature setting?
November 26, 2014, 11:03 |
Rep Power: 12 |
hi LuckyTran. you can see operating temperature/density in cellzone conditions-operating conditions-on rightside (below) of the panel when you activate boussinesq approximation.
November 26, 2014, 11:33 |
Rick
Rep Power: 26 |
Operating temperature is shown only when boussinesq approximation is on.
Google is your friend and the same for the search button! |
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 06:29 |
Questions about operating conditions setting in fluent. | Frank Yang | FLUENT | 6 | May 18, 2013 04:08 |
Reference Pressure Set Up | Explorer | FLUENT | 0 | May 11, 2011 02:58 |
Grid scaling & Operating conditions | shankara.2 | FLUENT | 0 | May 28, 2009 13:56 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
