July 31, 2013, 21:02 |
System coupling doesn't detect participants
Anonymous
Rep Power: 13 |
Hi Guys,
I am doing a two-way FSI using system coulping with FLUENT and Static structural. But for some reason, the system coupling setup doesn't detect the participants. I have connected both FLUENT and Static structural setups to it. Is it a licensing issue? Can something be done to fix it?? I would greatly appreciate any inputs.. Sincerely, AGP |
August 2, 2013, 08:39 |
Rep Power: 21 |
What are the errors in the Fluent, System Coupling and Structural output files? It could be licensing. If you are using academic licenses make sure shared licensing is disabled in the license preferences.
August 6, 2013, 16:01 |
Anonymous
Rep Power: 13 |
There are no errors in FLUENT and static structural. The participants aren't detected in the system coupling section. I have disabled shared licensing. Any other suggestions??
August 7, 2013, 08:58 |
Rep Power: 21 |
Could you turn on the debug output in System Coupling to "All Levels" then copy the last section of the System Coupling output here?
August 7, 2013, 13:04 |
Anonymous
Rep Power: 13 |
Thank you so much Stumpy for your response. I have turned on the debug output in System Coupling to "All Levels". But I don't see any output or any error messages. Can you please let me know which section are you exactly talking about.
August 7, 2013, 15:31 |
Rep Power: 21 |
There were no Data Transfers defined in that screen shot - see the question marks in the tree. Is that the case you are trying to run?
August 7, 2013, 16:11 |
Anonymous
Rep Power: 13 |
Yes. This is the case I'm running. I can't define data transfers because the participants aren't getting detected.
August 7, 2013, 17:38 |
Rep Power: 21 |
Ah, I see. I thought this was when solving. That's strange, never seen that happen. I assume there's an FSI interface in the Static Structural system. Does the oscillating plate tutorial work OK?
August 7, 2013, 17:51 |
#9 |
Anonymous
Rep Power: 13 |
I forgot to click on update project!!
April 12, 2019, 12:08 |
Thanks!
#10 |
Viraj Gandhi
Thanks for the solution!
I wouldn't have been able to guess! |
March 2, 2020, 01:19 |
#11 |
Rupali
Rep Power: 6 |
I am also facing a same kind of error (see attached). Please suggest me how to resolve the issue.
https://ibb.co/rf73GQT |
Remeshing_ ANSYS 14.0_ System Coupling | acdesa | ANSYS | 4 | November 2, 2016 09:12 |
system coupling ansys 14 - error | karupps8 | Main CFD Forum | 1 | May 20, 2014 21:36 |
How can I track the progress of FLUENT when running ANSYS System Coupling | yhy20081016 | FLUENT | 1 | June 4, 2013 12:03 |
2-way FSI, System Coupling error | Arty | Main CFD Forum | 1 | May 12, 2013 14:41 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
